'01 VATS keygold10go4 04-16-2009, 08:21 PM I have the VATS system and bought a Buick key with the same resistance value as the ignition key I have. I am assuming that all I have to do is cut the key same as the existing. Is that all I need to do to have a spare key? I'm assuming the new key doesn't have to be programmed since the resistance values are identical. ctwright 04-16-2009, 09:16 PM I have the VATS system and bought a Buick key with the same resistance value as the ignition key I have. I am assuming that all I have to do is cut the key same as the existing. Is that all I need to do to have a spare key? I'm assuming the new key doesn't have to be programmed since the resistance values are identical. That is correct. gold10go4 04-17-2009, 08:07 AM Thanks, ct, for taking the time to respond. Automotive Network, Inc., Copyright ©2012
