96 regal crankshaft sensor?rickard69420 04-16-2009, 07:27 PM 96 buick regal 3.1 260,000km 3 days ago my car ran fine, the next day i put in my relay for a/c and my fuse for abs(took it out for the winter), and tried to start it and would not start! after some research on the web i summed up to be the crankshaft sensor (2 pin, side of the block) there are 2 on this car, the other is behind the crank pulley. gm said it is usually the one on the side of the block. so i went ahead and bought the part. got home and after some time i found it. boy is that tight!! anyways i got the bolt out and you think i could budge the sensor, nooooo! so my question is, how do you get it out? there is very little room for any type of screwdriver or a pry thing a ma jobber!! lol. thanks in advance!! rickard rickard69420 04-17-2009, 03:07 PM any ideas, anyone? rickard69420 04-20-2009, 10:48 AM ok well thanks everybody, don't all of you jump at this at once. Fire7 04-17-2010, 03:28 PM I have a 96 buick regal, i am also having crankshaft position sensor problems. i know where the one behind the ballancer is. where is the other one you are talking about. if i have any luck. ill let you know whats up. big white bufflo 04-18-2010, 07:25 PM there is only one crank sensor the other is the cam position sensor the crank sensor is located behind the harmonic balancer it take a little time to change the cam sensor is located to the left of the water pump below the pully it take only 1/2 hr at best to change Fire7 04-19-2010, 12:50 AM hold on, before replacing the sensor you need to have it diagnosed. its free at auto zone. make sure your replacing the correct sensor. i read something in a post about there being a bolt in the block losen that bolt and it will take the pressure off the sensor. i wouldnt recommend doing that till you have researched that farther though. cause like I said. i just remember seeing something in a thread. I may not be on the right track with it. Automotive Network, Inc., Copyright ©2012
