Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 04-16-2009, 02:28 PM   #1
jimneo
jimneo Normal reputation
Exclamation timing problem 1992 accord
need info on how to adjust timing on a 1992 accord please help
jimneo is offline   Reply With Quote
Old 04-17-2009, 01:23 AM   #2
mpumas
mpumas Normal reputation
Re: timing problem 1992 accord
First jumper the service connector, then connect a timng light to the no. 1 spark plug wire. Remove the rubber plug near the flywheel. Start the engine and let it warm up. Point the timing light into the inspection hole near the flywheel and look for a pointer and red and white mark on the flywheel/drive plate. Proper timing is when the red mark is under the pointer. (The white mark is TDC.) Timing is changed (adjusted) by loosening the 3 bolts on the distributor and rotating the distributor. (Timing is controlled by the computer and adjustment is not normally requiired unless it is well out of the range that the computer can control.) Turn off the engine and remember to remove the service connector jumper.
mpumas is offline   Reply With Quote
Bookmarks
Google
Web AF
