32" MTR'sAg_xterra 10-23-2001, 02:44 PM here are my newly installed GY 32" MTR's. warning driveway shot!!! tests/actions shots soon to follow... Philosopher 10-23-2001, 02:58 PM Lookin' good Jason! :bandit: Ag_xterra 10-23-2001, 03:20 PM thanks. now these give me an excuse to wheel daily instead of my usual weekly trip. ha ;) rrdstarr 10-23-2001, 03:33 PM Those look like nice tires! First time I have seen someone in a long time put the white lettering on their tires to the outside! Not being a smartass, just an observation! :) Maddog 10-23-2001, 03:35 PM Yea man, looks good. Keep us posted as to how they perform. I'm seriously considering these as my next tire. Dog:bathroom: Schludwiller 10-23-2001, 04:13 PM You know the blue stuff comes off the lettering right? Philosopher 10-23-2001, 04:15 PM Originally posted by Schludwiller You know the blue stuff comes off the lettering right? He likes those blue-walls! xoc 10-23-2001, 04:40 PM Look Mike ! 32's without a lift or hugely cranked torsion bars ! Woohoo ! Ag_xterra 10-23-2001, 05:35 PM yes, i was aware that the blue stuff comes off the white lettering. the picture was taken minutes after the tires were installed today so i didnt have time to clean that blue crap off. i will do it soon. as for the lift, no i dont have a true lift on my X but i do have my torsion bars cranked up about 1.25" and a fabtech AAL in the rear. Schludwiller 10-23-2001, 05:42 PM Originally posted by xoc Look Mike ! 32's without a lift or hugely cranked torsion bars ! Woohoo ! Hmmmm....1.25" of torsion bar lift, and AAL's in the rear sure doesn't sound like stock Ian. :silly2: xoc 10-23-2001, 05:49 PM Originally posted by Ag_xterra as for the lift, no i dont have a true lift on my X but i do have my torsion bars cranked up about 1.25" and a fabtech AAL in the rear. Take this measurement, and post the results here please. http://www.xterrain.com/images/x%20front%20adjustment.jpg Philosopher 10-23-2001, 05:50 PM Originally posted by xoc Look Mike ! 32's without a lift or hugely cranked torsion bars ! Woohoo ! Who said anything about "hugely cranked"? You describing your ego again? :flipa: I said you can't fit 32's on the X without cranking the torsion bars, and you can't ... unless you want to remove your fenders the hard way. xoc 10-23-2001, 06:09 PM Originally posted by Philosopher I said you can't fit 32's on the X without cranking the torsion bars, and you can't ... unless you want to remove your fenders the hard way. Sure... http://www.xterraownersclub.com/images/xotwbig16.jpg Why must you go on and on with this nonsense ? Adjusting the torsion bars does not alter the suspension in any way. The amount of upward travel and downward travel are exactly the same as a stock Xterra. Travel is limited by the bumpstops, and nothing else. Adjusting the torsion bars alters the ride height, but when the suspension is fully compressed the wheel is in exactly the same place regardless of whether the ride height is adjusted, or whether a lift kit is installed. Please tell me why the wheel can no longer travel all the way up if the torsion bars are cranked. This is such a simple thing Mike, and I have to wonder why you try to convince yourself and others that it is not a fact. Schludwiller 10-23-2001, 06:39 PM Ian, doesn't pre-loading the torsion bars reduce how fast the torsion bars reach the bumpstop or is it even speed regardless? I know your argument is about where the wheel is under full suspension trouble, but I am curious about this point. Also, adding new torsion bars had more of an effect on my rubbing problems than anything. xoc 10-23-2001, 06:57 PM Originally posted by Schludwiller Ian, doesn't pre-loading the torsion bars reduce how fast the torsion bars reach the bumpstop or is it even speed regardless? I know your argument is about where the wheel is under full suspension trouble, but I am curious about this point. Yes, it does, since you're stiffening the spring. Mike's claim may come from the fact that he isn't using up all the travel due to the torsion bars being so stiff, but it's no reason to say 32's won't fit. No matter what, 32's will rub, lift, cranked or stock, but they will "fit" in any situation. warmonger 10-23-2001, 07:09 PM If you look closely at the clearance on the L/F tire of both trucks at the rear wheel well you can clearly see how close the clearance is. I would be surprised if they don't rub at full articulation. I have to agree with XOC on this one. You can add a suspension lift and you will increase your articulation proportionate to the amount of the lift. But it doesn't change your bump stop unless you replace it with a longer one, limiting your upward articulation. I don't condone the condescending attitude, but I do agree with the logic and facts as presented. I personally wouldn't put 32's on an unlifted truck unless I modified the rims in some way. But then you begin to put at risk your steering components. But even lifted, you still have to modify the rims to prevent rub due to the fact that suspension travel hasn't changed. xoc 10-23-2001, 07:19 PM Originally posted by warmonger I don't condone the condescending attitude, but I do agree with the logic and facts as presented. Sometimes that's the only choice. I've been trying to explain this to Mike for a month or two now. warmonger 10-23-2001, 07:37 PM Originally posted by Schludwiller Also, adding new torsion bars had more of an effect on my rubbing problems than anything. I don't know which torsion bars you added, but I am going to go on the assumption that they are Sway Away. If so, they are 30% stiffer I am guessing. This will reduce the rate at which the front end drops. But if you have the added weight of an ARB and winch, you will offset this somewhat although not completely. You can still compress the front suspension fully, it just takes more work. Stiffer shock absorbers will also effect it somewhat. But again, neither of these changes the articulation. Just the speed with which it articulates and the force it requires to reach full articulation, thus reducing how often it actually hits the contact point. Ag_xterra 10-23-2001, 08:20 PM measurement A = 13.5" measurement B = 11.0" thus making measurement H = 2.5" Maddog 10-23-2001, 08:47 PM Not trying to join the fray, but my 32x10.50 TSLs would not fit without cranking the t-bars. I have since added an SLR suspension lift, but they would not fit on my stock truck without altering the ride height. Dog xoc 10-23-2001, 08:58 PM Originally posted by Maddog Not trying to join the fray, but my 32x10.50 TSLs would not fit without cranking the t-bars. "Fit" how ? xoc 10-23-2001, 09:00 PM Originally posted by Ag_xterra measurement A = 13.5" measurement B = 11.0" thus making measurement H = 2.5" Thank you, 0.6" over stock. My mistake, it didn't look that high in the photo. Any alignment problems ? Ag_xterra 10-23-2001, 09:48 PM well i do believe i was below the recommended factory ride height of 1.79". when i measured from the body mount closest to the torsion bar adjuster nut i raised it a total of 1.25". the O.D. of my 32's are only 31.5" actual. if they were swampers i'd probably have alot more rubbing issues on road. dealership said it was difficult to get all the specs back into alignment but they were able to get it pretty close. xoc 10-24-2001, 01:29 AM Originally posted by Ag_xterra well i do believe i was below the recommended factory ride height of 1.79". when i measured from the body mount closest to the torsion bar adjuster nut i raised it a total of 1.25". That sounds about right when compared to the factory measurement point. The factory point is inside from the centerline of the tire, so your measuring only part way along the triangle. Philosopher 10-24-2001, 11:31 AM Originally posted by xoc Sure... Why must you go on and on with this nonsense ? Adjusting the torsion bars does not alter the suspension in any way. The amount of upward travel and downward travel are exactly the same as a stock Xterra. Travel is limited by the bumpstops, and nothing else. Say what? How can someone with "20 years of experience" say something so foolish? This is utter bullshit. When you crank up torsion bars, you push the upper bumpstops closer the the upper control arm, thus limiting your travel. The amount of travel a stock Xterra has versus an Xterra with torsion bars cranked up is different, and everyone who has cranked their t-bars up even just a little bit should be able to notice the difference in ride quality since they don't have as much down travel as they did when their truck was stock. Adjusting the torsion bars alters the ride height, but when the suspension is fully compressed the wheel is in exactly the same place regardless of whether the ride height is adjusted, or whether a lift kit is installed. Please tell me why the wheel can no longer travel all the way up if the torsion bars are cranked. This is such a simple thing Mike, and I have to wonder why you try to convince yourself and others that it is not a fact. http://www.maxc.org/images/banghead.gif What you're saying about this maybe fine in theory but not in practice. You say that some guy in your club has gotten 32's to fit under his Xterra without cranking the torsion bars? Fine. He's the only guy I know of who didn't have to crank his t-bars at least a little bit to make 32's fit. Maybe his t-bars were cranked a bit higher from the factory than everyone else's. Maybe his front suspension is magical. Either way, everyone else has had to crank up the torsion bars to get 32's to fit. That is my point and that is what I tell people who ask me: To get 31's to fit under an X, you need to trim the plastic around the wheel wells. To get 32's to fit, you have to trim a bit more plastic and crank the torsion bars at least a little bit. OffroadX 10-24-2001, 11:50 AM Travel is NOT altered. The maximum upward stuff and downward droop (the full suspension travel) does NOT change. The only things that change with a t-bar tweak are the distances from "rest" to max upward travel and to max downward travel. You can call this "reduced down-travel" and "increased up-travel" if it makes you happy, but it is certainly not reduced droop or increased stuff, which would be a change in true suspension travel. The "change in ride quality" is not related to "reduced down-travel", it is because the increased pre-load on the bars makes the suspension less willing to "give" to the smaller changes in the road surface and therefore transmits more to the body, as well as reducing roll somewhat. Brent Philosopher 10-24-2001, 11:56 AM Originally posted by OffroadX The only things that change with a t-bar tweak are the distances from "rest" to max upward travel and to max downward travel. Yeah, i.e. reduced down travel. I think most folks reading this know what I mean. OffroadX 10-24-2001, 11:58 AM But reduced down travel has nothing to do with making tires fit. The tweak that causes it does make the rubbing less frequent, but no less likely. Brent Philosopher 10-24-2001, 12:01 PM Originally posted by OffroadX But reduced down travel has nothing to do with making tires fit. Brent Read my last paragraph 4 posts up. Did you crank your torsion bars up a bit to fit your 32" KO's Brent? Philosopher 10-24-2001, 12:40 PM Originally posted by OffroadX The tweak that causes it does make the rubbing less frequent That "tweak" is what saves your fenders from being wrecked and your tires from being worn down and cut up prematurely ... that is my point and has been from the beginning - can you fit 32's under an X without cranking the torsion bars? Probably, but you can't drive down the street (or hit a trail) with them like that without damaging something sooner or later. I don't claim to know it all, or even most of it. But I do know that you need to crank up the t-bars a little bit to fit 32's under an X to have no rubbing ... I know, I did it 2 years ago. After trimming a shitload of plastic in front of and behind the front wheel well I had to crank them up a bit to stop the rubbing issues. This is getting really old - I tried to help someone out on XOC by telling them they would need to crank up their t-bars a bit to fit 32's and all this crap is the result of that. Was my initial statement correct? Yes. Next time I'll just ignore 'the whiners' (an Ian term) and/or just keep my opinion to myself and let someone with more years of wheeling experience (you :rolleyes: and Ian) answer instead. an1malch1n 10-24-2001, 12:54 PM Philo...there isn't any reason to get mad. But what Ian and offroadX have said is true. Just cranking up the t-bars will help relieve rubbing becuase of the pre-load you have on your t-bars. I.e. making it harder for it to "stuff" the tire into the wheel well. I guarantee if you were to jump your truck to make sure you are getting all the susp travel used up you would end up with the same amount of rub as the person that hasn't cranked his t-bars. You haven't really altered anything. The position of the wheel at full tuck is the same whether you cranked the t-bars or not. Sorry man. I see what you are saying but Ian is right. Philosopher 10-24-2001, 01:08 PM Originally posted by an1malch1n Philo...there isn't any reason to get mad. I'm not mad, just tired of debating something that started out as one small question and ended up being a thread on 2 different boards - partly my fault of course, but nonetheless ridiculous. This all started when I said: "Twisting the torsion bars is (part of) a 'poor man's lift' and enables you to run 32" tires under an Xterra whereas without doing that you can only fit 31's. I'm not trying to argue here, just trying to point out the logic." posted 10-18-2001 11:32 AM in XOC under Hardcore 4WD, topic named "Which lift first". Anyone who wants to put 32's under an X without cranking the t-bars, have at it. Sorry man. I see what you are saying but Ian is right. Okay, Ian is right. :) :rolleyes: :bonghitte Schludwiller 10-24-2001, 01:25 PM I think both points are valid. Yes you can put 32's without mods on a Xterra if you're going to park it on a meadow. (my opinioin, but all the rubbing would drive me nuts, much like my SSR's with an ARB and Winch. Only getting heavier duty torsion bars stopped this). Adjusting the torsion bars doesn't limit physical travel, but pre-loads the bars so your larger tires have less of a tendency to rub against your upper fender. Ian's definition of "fit" is if they're in there. Philo's definition of "fit" is if you can drive offroad with a minimum of rubbing. Any dissention with the above statement? Please provide your final opinions and I'm going to lock this thread. Philosopher 10-24-2001, 01:39 PM Originally posted by Schludwiller Philo's definition of "fit" is if you can drive offroad with a minimum of rubbing. Offroad or even onroad over potholes or small bumps. Sorry Schlud, didn't mean to make a mess of this. I'll go back to my bong now ... Schludwiller 10-24-2001, 02:12 PM I don't mind the debate. :licker: It just seems everything has been said now. xoc 10-24-2001, 05:14 PM One last question Mike. Define "fender". Are you saying the tire is hitting the sheet metal of the fender, or do you mean the plastic trim on the bumper, or the mud flap ? Here are 2 pictures showing a tire stuffed as far as it will go, both taken at the same time on an RTI ramp. The tire still has a lot of room to the fender, even if the wheel was turned. http://www.xterrain.com/images/stuffed01.jpg This shows the compression of the lower bumpstop. I'm running a shorter poly bumpstop now, and still don't come near the fender. http://www.xterrain.com/images/stuffed02.jpg Mike, you yourself posted a picture (from the area shown on your MAXC bio page), of "major stuffage" and there was still clearance. Where exactly does it rub ? OffroadX 10-24-2001, 06:01 PM The only place I've rubbed is the plastic liner at the upper front of the wheel well, bascially just under and behind air intake. Brent xoc 10-24-2001, 06:08 PM Originally posted by OffroadX The only place I've rubbed is the plastic liner at the upper front of the wheel well, bascially just under and behind air intake. Same here, and also one of the push-pins that hold the rear of liner on, but only the passenger side. Certainly not tearing off a fender. Philosopher 10-25-2001, 11:55 AM Originally posted by xoc One last question Mike. Define "fender". Are you saying the tire is hitting the sheet metal of the fender, or do you mean the plastic trim on the bumper, or the mud flap ? The areas that can be contacted / torn up by 32's = the stock front bumper (or even an ARB as some have found out), the fender lip moulding, the wheel well lining, the stock 'mudflap' in the rear of the front wheel well. Philosopher 10-25-2001, 12:02 PM Originally posted by xoc This shows the compression of the lower bumpstop. I'm running a shorter poly bumpstop now, and still don't come near the fender. http://www.xterrain.com/images/stuffed02.jpg No upper bump stops at all? I also ran the Energy Suspension Low-Profile Bump Stops on the lower control arm for a while but removed them because they were just too short and I kept bottoming out. Philosopher 10-25-2001, 12:03 PM Originally posted by Philosopher Read my last paragraph 4 posts up. Did you crank your torsion bars up a bit to fit your 32" KO's Brent? Didn't want to answer me Brent? OffroadX 10-25-2001, 01:08 PM I started to, but I couldn't come up with a good way to phrase it. I guess the best way to say it is I made a half-assed attempt but started cranking backwards. By the time it was all over, I don't think I ended up adding any height. The ad-hoc measurements I took before, during, and after didn't really indicate a change. Seeing how it was the night before I left for Shamokin, I didn't have time to really do it right. However, in the 2 days between getting them mounted and attempting the tweak, I didn't get any rubbing around town (and I was testing for it). Brent Schludwiller 10-25-2001, 01:28 PM Originally posted by OffroadX I started to, but I couldn't come up with a good way to phrase it. I guess the best way to say it is I made a half-assed attempt but started cranking backwards. By the time it was all over, I don't think I ended up adding any height. The ad-hoc measurements I took before, during, and after didn't really indicate a change. Seeing how it was the night before I left for Shamokin, I didn't have time to really do it right. However, in the 2 days between getting them mounted and attempting the tweak, I didn't get any rubbing around town (and I was testing for it). Brent Use your ESM and take the measurements Ian posted here. At least you can find out where in the spec you fall. xoc 10-25-2001, 03:51 PM Originally posted by Philosopher No upper bump stops at all? It's there. Bad photo angle :) OffroadX 10-25-2001, 04:17 PM Originally posted by Schludwiller Use your ESM and take the measurements Ian posted here. At least you can find out where in the spec you fall. Ian posted the diagram, why do I need my ESM? :D Brent Philosopher 10-25-2001, 05:19 PM Yikes ... Brent riding Ian's coat tails. This could get ugly. :huh: Schludwiller 10-25-2001, 07:26 PM Originally posted by Philosopher Yikes ... Brent riding Ian's coat tails. This could get ugly. :huh: I believe it was actually a dig at Ian for posting copyrighted material on the internet. OffroadX 10-26-2001, 10:37 AM Hadn't thought of that. Actually was simply pointing out that I didn't need my ESM since the diagram was already here. In other words, I was busting your chops a bit :) Brent Schludwiller 10-26-2001, 11:38 AM Originally posted by OffroadX Hadn't thought of that. Actually was simply pointing out that I didn't need my ESM since the diagram was already here. In other words, I was busting your chops a bit :) Brent I'll remember not to overestimate the depth of your humor next time then. :flipa: :D Automotive Network, Inc., Copyright ©2012
