Originally Posted by HotZ28
The FP relay ground is activated by the PCM when the ignition switch is turned to either run, or start. Power (12v) to the relay comes from fuse #6 with ignition turned to run, or start. The grey wire feeds the FP control module and the module may have a black ground wire, or it may just ground to the chassis. My schematic shows two separate wires going to the FP motor, grey & pink. The FP motor is grounded to the chassis. When the switch is turned to run, the PCM provides a 2-sec prime and then drops the ground to the relay. If start the engine, the PCM provides a continuous ground to the relay. No one particular sensor is used, the PCM automatically knows when the engine starts!
Thanks for the reply. Let me clarify:
We are talking about the function of two different devices: the fuel pump relay and the fuel pump control module.
The PCM does not supply ground or control "ground" to the fuel pump relay, it supplies 12V + to energize the relay. Ground is continuously supplied to the relay at its #2 post via the BLK/WHT wire. So says my manual, so says my multimeter when troubleshooting the circuits. As I stated, the 12V + is not being properly supplied by the PCM. That is why I asked what inputs does the PCM sense to supply this output to the fuel pump relay. The PCM is a computer, it "knows" nothing. It supplies finite outputs given finite inputs, within specified parameters. Either the PCM is bad, or it is not recieving the correct input from its sensors. Exactly which sensors does the PCM need input from to supply proper 12V + output feed to the fuel pump relay? If I can discern that, I can test them for proper function.
The fuel pump relay does not output to the fuel pump control module via a grey wire, it outputs to the fuel pump control module via a red wire.
Could you give me a detailed explanation of how the fuel pump control module functions, including all modes (this is a 2 speed pump)? That would help a lot.
