Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 04-15-2009, 05:48 PM   #1
dirtymazda
dirtymazda Normal reputation
Question no power to the fuel pump
This is the first mazda truck i have ever owned. its a 92 b2600i 4x4 standard cab. what happened is when i bought it the guy didnt tell me about the gas tank leaking and i didnt see it when i bought it. it only had a quarter tank and it was leaking around the seam. so i bought a new tank and drove it home to put it in. i got everything switched over too the new tank and now im not gettin power to the fuel pump. i hotwired the pump and it works. but when i connect it to the plug it doesnt. ive checked it with a voltmeter and it says .5 volts at the plug. i dont think i couldve pulled a wire loose because i had plenty left over when the tank was almost out and there was no tension on it whatsoever. when we connect the fuel lines and try to start it will start but then shut off immeidiatly. if you have any ideas on what could be my problem it would be greatly appriciated. thanks for taking the time to look at my problem. i am lost when it comes to working on mazdas. ive owned chevys my entire life
dirtymazda is offline   Reply With Quote
Old 04-16-2009, 12:26 PM   #2
oldgray
oldgray Normal reputation
Re: no power to the fuel pump
My mazda has a carb so I'm only guessing. Did you follow the wires to see if there's another wire harness farther down the line? Or maybe accidently blow the fuse? Good luck.
oldgray is offline   Reply With Quote
Old 04-16-2009, 02:02 PM   #3
dirtymazda
mine is fuel injected and from what i could see it only has a relay inside the drivers kick panel by the clutch pedal. Ive checked all the fuses and they are all good. im goning to follow the wires tonite or this weekend sometime to be sure something isnt pinched or broken. i dont think i pulled anything but im gonna check just to be safe. i really dont know what else it could be other than the wiring.
Old 04-29-2009, 06:44 PM   #4
dirtymazda
ok so the relay was bad. got a new one. then it started but would shut off immediately. took 3 weeks to find out what the problem was. MAKE SURE THE INTAKE TUBE IS ON!!!!! hahahaha im a dumbass sometimes
Old 04-30-2009, 07:54 AM   #5
oldgray
Glad to hear you figured it out! How did it go when you replaced the tank?
Old 04-30-2009, 08:10 PM   #6
dirtymazda
it ran fine. the tank itself was actually easer to replace than i thought. althought the sending unit has seen better days, i still need to figure out why the fuel gauge wuit working on me. id rather deal with that and carry a can full of gas around than worry about leaking half a tank on the ground im goin to see what i can find this weekend since i have nothing to do and its supposed to rain all weekend.
Bookmarks
Google
Web AF
