hard starting sometimes!jason235744 04-14-2009, 02:30 PM hey guys i have a problem , with crank time, it takes over 20 seconds sometimes for the engine to fire up, it does not do this all the time , but enought the wife is afraid to drive it. evertime i get it to do it , the dam thing will start by the time i get someone to turn the car over to check for fuel , spark etc. i saw that several people had the same problem but did not ever see a fix!! thanks for any information, the car is a 99 ghutchin 04-14-2009, 02:32 PM Is the MIL on? Once it is running are there any other issues? How does it drive? Does it do it when then engine is cold, warm or both? jason235744 04-15-2009, 07:44 AM no codes, the car runs and drives great no other problems at all, does not seem to matter if the car is cold or hot. ghutchin 04-15-2009, 08:57 AM This sounds like its along the lines of faulty fuel pressure regulator, although people tend to only see this issue when the car is warm. Can you pull the vacuum tube to the fuel pressure regulator and see if there is gas in the vacuum line. If there is, then that is your problem. The issue could also be related to something like the crank position sensors, although if those were failing i would expect that you would get some other drive-ability issues. Automotive Network, Inc., Copyright ©2012
