Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Jeep > Grand Cherokee/Grand Cherokee SRT8
Old 04-13-2009, 06:21 PM   #1
johnson110
johnson110 Normal reputation
1994 Grand Cherokee
Hi, I had my jeep inspected has 184k on it, he passed it but told me it need front end work,
I look under and the sway bar on one end is broken off it's mount, I want to take the mount off, it has an 18 mm bolt on one end and the other looks like a torx bolt, sprayed with pb blaster, not wanting to give at all, waiting for the fluid to soak in! Questions: what size is this torx bolt ? how much do these " sway bar mounts cost " ? The mechanic told me it needs a steering stabilzer, however, it shows no leakage, if I take the bar that is attached to the pitman arm is does have play in it. Any thoughts on this problem? Thanks
johnson110 is offline   Reply With Quote
Old 04-13-2009, 09:39 PM   #2
fredjacksonsan
Sir...I AM a professional
fredjacksonsan's Avatar
fredjacksonsan Normal reputation
Send a message via AIM to fredjacksonsan
Re: 1994 Grand Cherokee
Without looking at it, can't tell what size the torx head is. I'd think something like a T55 or so (that's roughly 9 or 10mm).
Steering stabilizer is, in effect, a shock absorber, so it could be worn out and not show anything on the outside. Old Man Emu makes a really good one, I'd recommend theirs if you are going to go aftermarket.
AF's RULES can be found HERE -- Please read them.
fredjacksonsan is offline   Reply With Quote
Old 04-17-2009, 11:23 AM   #3
johnson110
Thanks, Another question, got the nuts freed fron the "TORX" bolts, Is the bolt threaded into the mount, or can I it with a hammer and make it come out the other side?
Old 04-17-2009, 07:31 PM   #4
johnson110
Well I was able to get the bolts out!
Old 04-18-2009, 06:22 PM   #5
fredjacksonsan
(then you've found out they're not threaded....)
have a good one!
Bookmarks
Google
Web AF
