Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-10-2009, 10:46 PM   #1
valdivias
valdivias Normal reputation
Unhappy 2006 toyota corolla
i was on the freeway and and it would not go pass 2 rpm so now when i start it to drive it it runs for about 3 minutes then turns off and i cant rem it pass two. i got a dtc p2716 pressure control solenoid but i dont know where its at what should i do
valdivias is offline   Reply With Quote
Old 04-10-2009, 11:40 PM   #2
Airjer_
Airjer_'s Avatar
Airjer_ Normal reputation
Re: 2006 toyota corolla
how many miles on it?
if you are under 80k I would contact the dealer asap. There is a TSB for this ans I think it has to do with replacing the PCM. If you tell them the code I have no question that they will know what you are talking about as soon as they here it.
Airjer_ is offline   Reply With Quote
Old 04-10-2009, 11:54 PM   #3
valdivias
whats a pcm
Old 04-11-2009, 12:14 AM   #4
Airjer_
Airjer_'s Avatar
computer (Powertrain Control Module) or about $800
Old 04-11-2009, 09:31 PM   #5
roadrunner2
roadrunner2 Normal reputation
Code# P2716 is pressure control solenoid (like you said), and is located in the transmission to control the shift.
If the rpms are held back so as to not allow shifting to a high gear, the tranny slips into what is commonly called the 'limp mode'.
Still under warranty? If not.......
Have an reputable non-chain shop (preferably an independent) test and inspect.
The problem with doing nothing is not knowing when you're finished.
roadrunner2 is offline   Reply With Quote
Bookmarks
Google
Web AF
