95 escort retracting seatbelt noise
BIGPETEG24
04-10-2009, 08:07 PM
the drivers side retracting seatbelt cable came out the track and now is stuck, the clicking is very annoying any way to stop this noise:screwy:
Davescort97
04-11-2009, 05:11 AM
Could you pull the fuse? Probably not because I can't find an electrical diagram for it.
You could start pulling fuses until it quits, but it would probably disconnect some other things that you want.
AzTumbleweed
04-11-2009, 10:05 AM
Go down to the base of the pillar the belt is on and remove the trim. There is an electrical connection there. Just unplug it. There is also a bolt there that I think is a torx head. Turning it will manually move the shoulder harness. You can move it into the driving position and leave it there. I went through this with my car several years ago. I leave the shoulder harness hooked up and whenever I get in the car I simply pull it over my head and on to my shoulder.
