Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 04-10-2009, 06:06 PM   #1
FHamilton58
FHamilton58 Normal reputation
93 Accord - Key Beeper Beeps with no key in ignition...sometimes
93 Accord LX. About 70% of the time the key beeper is still beeping when the car door is open but NO key in the ignition.
Annoying, but not mission critical. Any ideas on the culprit?
Thanks
FHamilton58 is offline   Reply With Quote
Old 04-11-2009, 11:22 PM   #2
jaybur_racing
jaybur_racing Normal reputation
Re: 93 Accord - Key Beeper Beeps with no key in ignition...sometimes
buy some "tri-lube" from a local ace or hardware store. (it is recommended by locksmiths) spray some in there and then turn the key forward and back then pull the key out, do this about 10 times, each time wiping the key off (it will have tri lube on it)
what has happened is, "stuff" has gotten in the lock cylinder causing the "key in ignition" reminder to get hung up. (you can bang on the bottom side of the steering column and it will make it return to normal, but doing that every time is hardly fixing it).
hope this helps!
jaybur_racing is offline   Reply With Quote
Old 04-16-2009, 12:10 PM   #3
kega2
kega2 Normal reputation
pls is the car starting when you start,try and chek wen you put the is the light still blinking?
kega2 is offline   Reply With Quote
Bookmarks
Google
Web AF
