Re: Park Avenue won't start
Typical Passkey problem- Try cleaning the resistor pellet in your ignition key- then wait 4 minutes between failures- until security light quits flashing and try again-
if this does not work- then do some research- if you are mechanically inclined, you can bypass the security resistor with one of 14 known resistances- the two white wires inside the orange sheath under steering column can be joined by the correct value resistor (same as your key). I've done several this way.
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
