2001 Intrepid 2.7 has no compression or spark
mvestr1
04-09-2009, 06:59 PM
I got this car with motor partially disassembled. Set all three timing chains. Still has no compression in any cyllinder. Also no spark. Although I haven't had time to investigate that yet, I would appreciate any advice.
Thanks,
Mike
tempfixit
04-10-2009, 10:50 PM
Whats the reason for changing timing chain???
How many miles on vehicle?
Did you set the number one clyinder at top dead center compression stroke?? (No 1 clyinder passenger side front.)
Either the timing is off orall valves are bent, this is a INTERFERENCE engine.
mvestr1
04-11-2009, 12:31 PM
I reset the timing chain because when I got it the main timing chain tensioner had been reset, so there was no tension on the main chain. I did set #1 at TDC. Also when main timing chain was disconnected, the right side cams were much more difficult to rotate than the left side cams. I don't know if valves may be bent. Maybe it's time to pull the heads and take a look. 90,000 miles on motor.
