Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 04-08-2009, 04:31 PM   #1
juggie#1
juggie#1 Normal reputation
Question 1995 S-10 4.3 won't start
When trying to start engine gas load up in cylinder, remove spark Plugs spin engine over to clear gas out of cylinder. but when i try to start it again it load up with gas. thanks in advance
juggie#1 is offline   Reply With Quote
Old 04-09-2009, 10:08 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 1995 S-10 4.3 won't start
Just one cylinder?
TBI or multiport fuel injector?
what engine code?
If just one cylinder and MFI.
Check the injector for that cylinder.
Key on does fuel pressure bleed off fast.
What are fuel pressure readings?
Hit us with some more info.
MT
MT-2500 is offline   Reply With Quote
Old 04-09-2009, 08:16 PM   #3
juggie#1
It a Multi port fuel injector dump fuel in all cylinder, unplug injector still dumping fuel, also did change the fuel regulator valve thought that could have been the problem. It a four cylinder not a 4.3 sorry about that.
Last edited by juggie#1; 04-09-2009 at 08:18 PM. Reason: its a four cylinder not a v 6
Old 04-09-2009, 08:58 PM   #4
rhandwor
rhandwor Normal reputation
I would inspect the fuel line the return may have been damaged and pinched closed. You could blow air through to make sure it isn't plugged.
I would check for pulse to the injectors make sure it doesn't stay on all the time. Use a noid light or 12 volt test light.
Ohm the temperature sensor it should be around 4400ohms@60F and 2200ohms@85F. If way out of line post readings.
As the V-6 for this year has two injectors if you have only one it maybe leaking.
rhandwor is offline   Reply With Quote
Old 04-09-2009, 09:49 PM   #5
manicmechanix
manicmechanix Normal reputation
Do you have spark? Is it one cylinder loading up with fuel or multiple cylinders? I wouldn't think one cylinder getting flooded would keep it from starting.
manicmechanix is offline   Reply With Quote
Bookmarks
Google
Web AF
