Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Ranger/Courier
Old 04-08-2009, 01:20 AM   #1
westscoot
westscoot Normal reputation
2002 ranger/edge tranny
wont go from 1st to 2cd gear unless i let off the gas, or put gear shift in 1st then 2cd manually. Also overdrive light is blinking. its an automatic
westscoot is offline   Reply With Quote
Old 04-08-2009, 01:41 AM   #2
aspireelectronics
aspireelectronics Normal reputation
Re: 2002 ranger/edge tranny
Hi did you connect a scanner? and pull codes you can clear code after recording if any.try disconnecting the battery that might reset the system
you will need to check the tps sensor for glitches or drop outs if ok you headed to the transmission shop probably a solenoid problem but often they will try to sell a rebuild.
Regards
aspireelectronics is offline   Reply With Quote
Bookmarks
Google
Web AF
