Originally Posted by caw333
Well this happened back in NOV 2007 and I'm still chasing the problem. The ECT is the thing I"M on now. Its been 1 1/2 years and close to $2500 later and still trying to pin point what is causing my problem and throwing the single code of po341. The code is very vague and doesn't leave me or the two shop I had it in much to go on so its been alot of part and sensor changing. Right now I'm grasping at straws and trying to get an idea from any one who might know somthing I'm overlooking. Thanks
Are you telling us you drowned it back way back in nov 0f 97 and 2500$ later and 2 repair shops later and now you think it is a engine coolant sensor?
When the only code you have is a 341 camshaft sensor CIRCUIT problem?
WHAT YEAR AND WHAT ENGINE?
Coolant sensors do not drown out.
Coolant sensor is not your problem.
Get some good repair info and find a good repair shop that knows what they are doing.
A factory repair manual or a Online All data sub thhat has the code repair flow charts will led you right threw the repair for the code 341.
For camshaft sensor circuit problem.
Where it was drownded check all wiring and plugins for corrosion.
Was that salt water or fresh water drowned?
If salt water you could be in a world of hurt.
http://www.alldata.com/products/diy/index.html
