heat control issuesmeuhus 04-07-2009, 07:10 AM hello all i have just purchased a 1997 astro heater selector didnt work fixed vac line now selector works but only blows cold air unplugged vac line that plugs in under heater box in engine compartment near vac res ball and have heat is there something inside the box that is not working properly like a vac operated vent door thanks brcidd 04-07-2009, 08:33 AM Your temperature door is controlled by an electric actuator, not vacuum- check to see if axle of actuator moves with increasing/decreasing temp setting (with ignition on) - if it does, then actuator is ok-- remove actuator- and see if temp door is attached to axle- rotate it by hand, does it feel like it is moving the temp door? Actuator is on RH side of HVAC housing meuhus 04-07-2009, 05:33 PM so take the box in the engine compartment apart i cant see anything like your are describing in the engine compartment meuhus 04-08-2009, 05:29 AM hello again just an up date sorry to all this may seem trivial too but not familiar with the astro i crawled under it and the vacuum line i dissconected was to one of two vac. controled water valves. it seems that gm added every thing to make it have rear heat then sent it to an up fitter (mark 3) they didnt add the rear heater controls or rear heater core ect. the vacuum line i disconnected was from the lower of the 2 valves (it has the vacuum diaphram on bottom of valve). the upper water valve doesnt have any vacuum to it(it has a diaphram on the top of it) the heater temp selector works fine as long as i dont hook up to the vac line to this lower water valve should the upper water valve have vacuum present all the times the lower one doesnt have vacuum all the time i forget when it is present is there any vacuum diagram avalible for this? is it possible to finish adding the rear heater with out being a big pain brcidd 04-08-2009, 08:11 AM Those are heater shut-off valves- they are designed to block hot water flow to the heater cores when you select "full cold" on the temp selector. There should only be vacuum there when in full cold- Exercise the upper (front) water valve lever arm- they can tend to stick- test for yourself- you get heat when valve is open, no heat when closed. Normally folks complain that their cooling ability is amiss- because the water valve does not shut off- you have the opposite problem. GM did not send those vans to the upfitter-- the Upfitter bought them from GM- and then marketed through the dealers- so anything the upfitter did is out of GM hands-- I always hate to wotk on upfitted vehicles- you can't ever get a service manual style reference for them- who knows what hey have done- at one time there were over 2000 upfitters in the US- probably about 20 now.... meuhus 04-10-2009, 07:40 PM so can i lube this thing up or does it just need to be replaced yes it it sticking when the vacuum signal is gone not opening is it possibe to get the rest of the rear heater controls for the van would like to add the rear heat my self heater hoses are ran to the middle row of seats on driver side what else is needed to have the rear heat vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
