94 Camry ignition switch where is it? or is that my problem. read my explaination
I have been trying to trouble shoot a problem. First off, It would crank and start fine until you moved it, but you could jiggle the wires at the battery and it would start up. So I took those apart replaced the what seemed to be bad connector. cleaned everything up grease it up and such. Thats good now. Well it did it again, So i figured the starter might be bad because I tapped on it and it crank right over and started.Well it did it again, turn the key and nothing no clicking no nothing. So in my trouble shooting. I took a handheld starter button, jumped the starter motor and it cranked, hooked it back up hit the key switch, Nothing lights come on in the dash but won't crank. Samething nothing I also took my circuit tester and put it on the starter wire no juice.
So I have come to the conclusion it would have to be the igniton switch. unless somebody here with more toyota experience than I knows of something else.
