During the rebuild I torqued all the oil pan nuts and bolts to 100 in/lbs as per the manual. One of them was stripped but I was hopping it would not matter.
It did matter. The oil pan is leaking right at the stipped bolt.
What is the best way to repair this, preferrably without removing the oil pan? Helicoil? Tap? Replace the block?
Park it in the grass?
I thought maybe I could fashion a single bar-washer and put it under the bolts on either side of the bad one but I don't really want to put extra pressure on those two and risk another strip.
Thanks
