p1757
bub48161
04-04-2009, 11:27 PM
ok i got a 1996 JGC and i used my buddys code scanner and it pulled up P1757 and i want to know what it is. any help would be nice
xj31
04-05-2009, 11:11 AM
Does the trans shift ok?That code is for governor pressure above 3 psi at 0 mph
bub48161
04-05-2009, 03:04 PM
no it shifts like shit from 1st to 2nd and then it revs up to about 4000 when it shifts from 2nd to 3rd and some times i have to let off the gas for it to shift at all so do you think its the governor and i pulled up code 37 by doing the on off thing with the key
xj31
04-05-2009, 10:54 PM
I would have to suspect the governor pressure transducer.It's a pretty common thing.
bub48161
04-06-2009, 08:14 PM
so do you think i should change the governor pressure solenoid as we as the governor pressure transducer
tvguy07
05-21-2009, 08:47 PM
When I did mine, I changed only the transducer. I would also change the transmission filter at the same time, though.
nova73noir
06-10-2009, 09:03 AM
after change these part if your tranny shift 1st to second in high rpm change the output shaft speed sensor its just before the transfert case and you need a 1 " key. i already have this problem with my 98 and after changing this part my jeep runs fine. are you sure you get only one code with the scanner. the part i told you cost around 25$if you change it you have to do it faster because of the fluid hope thats help!!!
