hi there, i have a 1999 gmc yukon denali and occasionaly my gear shifter gets stuck in park i would have to play with the shifter in order to get for at least an 1hr until i can get it to release from park, can someone please tell me what to look for or what my problems is?? this would be so helpful..
My Truck does the exact same thing, does nobody have any answeres to this?
re;gear shifter gets stuck in park. On the brake pedal there is a sensor at top of pedal its bad clips in place w/cotter pin 30 bucks to fix to insure this is the problem next time it happens have someone else depress brake pedal and try to put it in gear as you look at brake lights THEY WILL NOT BE WORKING ! !
if there was a bad sensor, it would simply not work right, i have never heard a a sensor working sometimes and then not work other times, when sensors go bad they are bad right?
thank you for the response
