Re: 1999 ford ranger hard to shift out of park
Disconeect the cable from the transmission, if its still stiff disconnect from the shift lever. If the shift lever moves easier after disconnecting from the trans than its not the cable. If it moves free after removing from the shift lever than it is the cable. If its still stiff after removing from the shift lever its not the cable.
Likely it is the cable. There not that difficult to replace.
