Need to replace Z71 bearings
bjf1280
04-02-2009, 08:05 AM
The bearings are gone on the right rear of my 98 Z71. Can I do this myself or should I bring it some where? Also, should I do both sides? I've done ball joints, idler arm, starter, exc...so I think I could do it. Any help would be appreciated.
j cAT
04-02-2009, 10:19 AM
the rear bearings and seals should be replaced together.....both.
the diff fluids will also be replaced and make sure the internal magnet and diff is cleaned ..
the axles will need removal and if the plates are rusted replace them at this time..
wafrederick
04-02-2009, 11:29 AM
Also mark the caps with a center punch so they go in the right spot.Does it has a posi?Inspect the diff cover for bad rust spots and replace it if needed.
bjf1280
04-05-2009, 09:27 AM
Turns out its not the wheel bearings its a bearing or retaining clip in the diff. The right rear tire moves in and out about 1/4 inch ( which is why I assumed wheel bearings). The left side seems fine, so now what?
jyount
04-05-2009, 02:07 PM
Replace your c clips if you want, but I've never had any vehicle up in the air that didn't have some play end to end.
the axle has to be pushed into the side gears, then the c clip installed, and the axle pulled back out to seat the c clip into the side gear, so there has to be some movement, the difference between c clips in and seated, no way around it. They can get excessive I guess if the side gears or c clips have some wear, but they will never be "tight" with c clip design. If a full floater had play, ya theres problems, but this design will always have some.
bjf1280
04-05-2009, 11:30 PM
yeah I think I'll just drop it off at my mech., I dont know enough to start pulling the diff. apart, thanks for the help I'll post back with the results for future refference.
j cAT
04-06-2009, 09:25 AM
the axle should move inward out ward a small amount...
when it gets excessive you have wear in the diff...gears...this may be adjusted ...with shims..the gear teeth wear pattern should be checked. if the wear pattern is proper you have no problems ...
is this an issue,,, or are you just looking at things that you think is a problem...
