Tachometer for 1996 blazerjakeyf08 04-01-2009, 11:26 PM I have a 1996 blazer and it does not have a tachometer. Is it possible to install and aftermarket tachometer? and if so are the wires available behind the dash? MT-2500 04-02-2009, 10:03 AM I have a 1996 blazer and it does not have a tachometer. Is it possible to install and aftermarket tachometer? and if so are the wires available behind the dash? Just get one that is compatable for the 96 and has all wiring instructions with it. Good Luck mike2004tct 04-02-2009, 04:18 PM I have a '97 Blazer that didn't have a tach. I got a cluster from a '95 Blazer at the local salvage yard, and put it in, including swapping out the odometer wheels so true milage shows up. Everything works fine, all the required wiring is inside the dash. No modifications required. Here's a link to my original post; http://www.automotiveforums.com/vbulletin/showthread.php?t=520665 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
