Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Tahoe
Old 03-31-2009, 10:13 PM   #1
cab326
cab326 Normal reputation
1999 Tahoe starting problems
I just had a new remanufactured 5.7 liter engine installed in my Tahoe. The old one spun rod bearing but it would still start and run. Now after the new engine is in it will start when cold, run terrible and when it gets to around 150 degrees it shuts down. It gets no spark after it shuts off. Then it has to sit for awhile before it will start again.
cab326 is offline   Reply With Quote
Old 04-02-2009, 09:45 AM   #2
j cAT
j cAT Normal reputation
Re: 1999 Tahoe starting problems
measure the ECT resistance...for correct temp/resistance spec...
this is suspect with I'm assuming NO DTC codes..
j cAT is offline   Reply With Quote
Old 04-03-2009, 09:21 PM   #3
cab326
Thank you for the reply. I found the problem was th crank sensor. Replaced it and it runs like a champ now.
Old 04-04-2009, 03:09 PM   #4
j cAT
if they droped the sensor or installed/hacked the wiring this would cause this...
good luck,thanks for the reply
Bookmarks
Google
Web AF
