Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder/Terrano/QX4
Old 03-31-2009, 03:51 PM   #1
pistolpeterson
pistolpeterson Normal reputation
Headlight low beam problem, 1995 Pathfinder
My wife has a 1995 Pathfinder. The right headlight will not work on lowbeam. The bulb is fine. I've swapped it out and both the new and old bulbs are fine. The high beam works ok. The Driver side light functions well too.
Any ideas? The car needs to pass inspection.
pistolpeterson is offline   Reply With Quote
Old 03-31-2009, 03:56 PM   #2
Scrapper
Scrapper Normal reputation
Re: Headlight low beam problem, 1995 Pathfinder
you might want to replace bulb socket? do you have a cheap bulb your using if so get a better brand or try a new bulb socket.
Scrapper is offline   Reply With Quote
Old 04-08-2009, 03:51 PM   #3
fway
fway Normal reputation
It might be the turn signal switch. I had a similar problem a few years ago and had to swap out the switch. Now one headlight turns on spontaneously when the car is off. To fix it, I need to flip the turn signal on. Try messing with the turn signal switch when the lights are on.
fway is offline   Reply With Quote
Bookmarks
Google
Web AF
