2003 Silverado 1500 parking brake dash light and audible alarm on constantlyrpsuede 03-31-2009, 12:11 PM Two days ago my '03 Silverado stopped recognizing when I pop the parking brake loose and now dings incessantly while I drive and the parking brake light on the dash flashes on and off. I tried... 1.) Engaging and releasing the parking brake multiple times. 2.) Checked the brake fluid level (perfect level) 3.) Checked my owner's manual (not enough info in the manual) Before I take this to an auto shop, is there anything I can do myself to potentially fix this issue? Is this a common problem with an easy solution. I am handy with electronics, so if it is a simple electric switch replacement I could probably do it myself. I will be swinging by an auto parts store on my way home today to look at the service manual for the truck to see if there is anything in there. Thanks, Richard brcidd 03-31-2009, 12:43 PM At the base of the parking brake, there should be a mechanical switch and a wire that plugs into it-- check it- bend it back a little- it is probably just stuck on, or the light blue wire to it is touching a metal ground-- it is probably that simple- you may have kicked it with your foot at some time and cause it to ground out all the time... rpsuede 03-31-2009, 05:10 PM Thanks. I'll check it out. I did try to wedge my hand back there yesterday and thought I felt a switch, but it is a really tight space. I'm going to have to get in there with a flashlight to take a real look at it. I hope it's that simple. This constant "ding, ding, ding, ding, ding, ding..." is really annoying while I drive. I have to blast the stereo to mask it. Thanks again, R rpsuede 03-31-2009, 06:42 PM Well, I went to AutoZone auto parts store here in Phoenix and the service manual was no help at all. When I have a chance I will get out a flashlight and look for the switch and wires, etc. R Automotive Network, Inc., Copyright ©2012
