Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > El Camino
Old 03-30-2009, 09:35 PM   #1
Psymon
Psymon Normal reputation
I need help
Hi my name is Matt(or Psymon). I have always loved El Caminos since I was a little boy, and now I finally have one. It is a 1978, Gold/Tan, V8 305 2bbl. When I got it it had some problems but I fixed most of them. Recently I replaced the Distributor Cap, Rotor, Plugs, Plug Wires, Carborator, and Fuel Pump. Anywyas now to why I made this post. While it is idleing not in gear it is normal when I put it in gear it does the normal bog down but then it ildes fast then slow bounceing back and forth from the two. When I let off the brake it jerks once I give it more gas it is very rough and I feel it in the peddle, kinda like it is running out of gas even though I got a full tank. Once it gets going as long as I don't give it gas it is perfect, but once you give it more it does it more. Noe here is the the part that is makeing me mad. While it is going and I got my foot on the peddle it "skips a beat" by jerking forward and makeing a little pop noise then goes back to normal. If I floor it is acts like it stalled without the stalling part. That is as best as I can explain it if you got any ideas or need more info I will work on getting pictures for you to look at. Any and all respones are welcome/wanted.
Psymon is offline   Reply With Quote
Old 03-31-2009, 06:27 PM   #2
spanky79elky
spanky79elky Normal reputation
Send a message via Yahoo to spanky79elky
Re: I need help
just a quick question is it a elctric or manale fuel pump just sounds like it is going out
spanky79elky is offline   Reply With Quote
Old 04-01-2009, 12:06 AM   #3
Psymon
Re: I need help
It is a manual, but I replaced it. Is there a way I can test it to see if I got a bad one?
Old 04-02-2009, 05:38 PM   #4
7D8SS
7D8SS Normal reputation
Re: I need help
I would double & triple check the firing order, it sounds like you may have put wires on wrong plugs. Could also be wiring laying on an exhaust manifold & burned through. ~ Jon
Z15 EL
7D8SS is offline   Reply With Quote
Old 04-03-2009, 03:32 PM   #5
Psymon
Re: I need help
I did check that and they are on right with the correct fireing order, and it didn't start to happen untill a month or so after I changed the plugs, wires and cap.
Old 04-03-2009, 07:58 PM   #6
7D8SS
Re: I need help
If you haven't done it yet, change your fuel filter. If it isn't electrical, it sounds like a lean condition. You could be getting too much air or not enough fuel. It could be a vacuum leak or a clogged fuel source.
Z15 EL
Bookmarks
Google
Web AF
