95 Aurora Strut and Shock Recommendation Needed
danckwerth
03-29-2009, 07:15 PM
95 Aurora w/ 65K. Looks like it's about time to replace the struts and shocks. I've used the Monroe recommended parts on my 99 Park Avenue but not sure if there's a better choice for the Aurora. Any recommendations? Thanks Dan
ghutchin
03-30-2009, 01:13 PM
I had my originals on there until 180k. What makes you think you need new ones? The basic choices are Monroe Sensatracks, KYB GR2 or Delcos for the front strut. I put the monroes on. For the rear the choices are Monroe and Delco if you want to keep the air leveling system.
danckwerth
04-14-2009, 09:37 AM
thanks ... rear shocks seem to be leaking down slowly over time and i figure that after 14 years now might be a good time to change all four corners ...
ghutchin
04-14-2009, 10:17 AM
Rear shocks are easy. 45 minute job. I would do those now. The longer the rears leak the harder the air compressor needs to work. You don't want that to blow out. You could also remove the fuse temporarily until you get the rears fixed.
The fronts are struts which are a much more involved job (read as more $$$ + time = more $$$) and you will need an alignment when done.
Not trying to sway you from taking care of the fronts, but I would definitely do the rears.
