Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 03-29-2009, 11:27 AM   #1
jimco23
jimco23 Normal reputation
2004 classic HVAC vent flow
No matter what I set the HVAC flow control on, I get flow from all vents. On defrost, I still get flow from all vents. On defrost and feet setting, flow sill comes from the dash vents. Is there an easy fix?
jimco23 is offline   Reply With Quote
Old 03-29-2009, 11:00 PM   #2
manicmechanix
manicmechanix Normal reputation
Re: 2004 classic HVAC vent flow
I don't know that this will fix the problem but it's easy enough to do. Take the control panel out and check that the vacuum hoses that connect to the back of the mode selector switch are secure. But usually this problem makes the air not come out the corresponding vents in certain vent mode selections. I think the vacuum hose feed T's off the Evap line so you might check that it's secure.
I didn't think the air could come out all vents simultaneously. Your mode servo is probably bad and there's no easy fix to get to it.
manicmechanix is offline   Reply With Quote
Old 04-09-2009, 01:12 PM   #3
jimco23
Thanks Manic
I did not pull the unit out but I did listen for the vacume to see if there was a leak. I don't hear a constant vacume but, I can hear the vacume working on every other setting when I change it. It activates on the 1st, 3rd, and 5th setting not sure if this is normal. Sorry for the late response, no rest for the weary.
Bookmarks
Google
Web AF
