Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > GMC > Sierra
Old 03-29-2009, 08:57 AM   #1
beck5012
beck5012 Normal reputation
96 sierra f-brakes
2wd 350ci auto.180,000mls dont put on many miles a yr. yr ago f-brakes seem to be hanging..and the front pass. pulling to the right when applied..like at times real bad put on brakes pull quick to the right..like left one not working..I worked cal. back and forth/pump brakes then go and push cal back in on pass side after several times seemed to release. drive 1 mile then checked .released and cool..drivers side hot as H. and stuck..So went and replaced Both..bled up on blocks..seems like cant pump brakes without enjine running. pedal hard as a rock..and with engine running everytime release pedal engine like speeds up then back..and both brakes stuck again..??? so now what replace? I put over 100 in so far..Booster/master/lines??? also do you have to bleed different cuz of the anti lock thing..just did it the old way..
beck5012 is offline   Reply With Quote
Old 03-29-2009, 10:01 AM   #2
maxwedge
A990 racer
maxwedge Normal reputation
Re: 96 sierra f-brakes
2 things can cause this, contaminated brake fluid swells the M/C seals and causes blockage of the bypass port, second is collapsed brake hoses.
maxwedge is online now   Reply With Quote
Old 03-29-2009, 10:23 AM   #3
beck5012
Am going to get new lines/hoses. I did suck out all fluid and bleed until new came out..before replacing cal...will let ya know when new hoses are in..Thanks..
Old 03-29-2009, 02:24 PM   #4
beck5012
Talking Re: 96 sierra f-brakes
THANKS MAXWEDGE**** put on new hoses..released!!! works fine now..didnt think that both would be bad at same time..but thats what it was tho..Thanks again..problem solved...
Bookmarks
Google
Web AF
