1998 Regal LS won't start... totally dumbfounded..
heyraver
03-29-2009, 03:14 AM
Hello everyone,
I'm having trouble with my 1998 Regal LS.
Its a 3800, non superchared.
The mileage of the vehicle is unknown.
The car does not want to stay started. Right when
the motor fires up, it dies in a matter of seconds.
If I try to start it up again, it will turn over, but not
start up.
If I give it gas while starting the car,
it will start fine and stay running, but once I let
off the gas, the car dies.
The car has new plugs and wires, it has spark and is
getting fuel pressure. All voltages are fine on the
censors(most censors I could find at least).
The car did have Check Engine Light on.
I got the codes tested and the comp brought
up 4 codes. I don't remember what the codes
were, but all 4 codes were linked to some
kind of EVAP malfunction.
I had a friend take a look at my car and he said
that my MAP censor was full of oil..
He left the MAP censor off and pulled a
hose from the EGR valve and the car starts
up fine...
I don't know what could be? I'm totally stumped..
Any advice anyone?
BNaylor
03-29-2009, 09:40 AM
Pulled a hose from the EGR Valve? All it has is an electrical connector. It is electronic not vacuum operated. How much oil is on the MAP sensor? Some is normal since the PCV valve is is located under it.
Have you checked fuel pressure? What are you getting spec wise?
heyraver
03-30-2009, 09:32 PM
It wasn't an EGR valve, it was a fuel pressure regulator.
I didn't plug a fuel gauge in, but I pressed the pressure valve
and gas squirted out, so i'm thinking it has enough pressure.
I brought it to a shop today, so i'll see what they say tommorrow..
DMCGEE
03-31-2009, 01:30 PM
Please do let us know what you find out. I have a 96 GS that is doing darn near the same thing and no one can figure it out. Thanks
heyraver
04-01-2009, 11:33 PM
Okay, so I got it out of the shop
earlier today.
The problem was a really dirty throttle body
and Idle Air Control valve.
I notice a big difference in performance now.
DMCGEE
04-02-2009, 07:15 AM
Thanks for the info....I will check the same on my 96 GS.
