Re: 2000 stratus 2.4l died and won't start. help me please
check the fuel pressure like wafrederick said. could be fuel filter or fuel pump.
do you have any codes stored? how many miles does your car have?
you could check for compression too although even if a cylinder or 2 had bad compression it will usually start but run like ****.
you mentioned you changed the spark plugs and now it is getting spark, did you not have spark before?
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
