Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Tahoe
Old 03-28-2009, 12:05 PM   #1
navyguy79
navyguy79 Normal reputation
99 Tahoe no start
Hello all, I have a 99 Tahoe 4x4 5.7L. Five weeks ago I went home to Indiana on leave (military), first time the truck had seen severe cold weather. It started having trouble starting when engine was cold (open loop). I could cycle the key a few times allowing the fuel pump to cycle then get it started. I just chalked this up to cold weather and went about my business. I went out to my brother’s house which is open field in the country and the temperature dropped to 8 degrees without wind-chill. Truck would not start at all. Spent the night there and was supposed to drive back that day. I called my other brother who lives in Indianapolis and had him bring down parts that all have sensitivity to humidity and cold weather. We changed out the coil and ignition module before checking for spark, I know I know, but had clean strong blue spark. We shoveled the driveway and got it pushed into the barn. I checked the fuel pressure and it was around 60psi ruling out the fuel pump. I thought maybe the diaphragm in the fuel pressure regulator was going out, cold weather making it worse. I put a hair dryer on the intake above the regulator for a few minutes and it started right up. I loaded up and drove 13 hours home only shutting it off for gas. Once I got it home it was back to the same thing, no start, cycle the key a few times and it would fire up and start rough then smooth out. I thought I’d change the fuel pressure regulator when I could get some time. I did some travel overseas for a few weeks and it did the same thing for a few days, until it finally died for good. Now it won’t start at all, smells flooded after cranking and I get a P1351 code (ignition control circuit high voltage). After printing out the schematic and tracing things through four pages it looks like the ignition signal routes from the VCM to the EGR, crank position sensor, ignition module, coil, and looks like the pulse for the injectors. So what I thought was a fuel problem not seems to be electronic so I guess I’ll start pulling sensors and doing the good old Ohm check looking for a sensor that was going out and is now officially dead, check connections, double check my grounds, then hooking up jumper wires looking for the bad section of wiring. Does all of this sound like I’m on the right track? Anybody seen this before? Common problems I should be aware of? I need to go back out and make sure I still have spark before jumping all over this but I bet $100 I still have pretty blue spark. Thanks for any and all replies.
navyguy79 is offline   Reply With Quote
Old 03-28-2009, 10:02 PM   #2
roadrunner2
roadrunner2 Normal reputation
Re: 99 Tahoe no start
Did you ever change the fuel pressure regulator?
After smelling gas you should have pulled the vacuum line off and see if fuel came out.
If it did/does, replace the regulator.
The problem with doing nothing is not knowing when you're finished.
roadrunner2 is offline   Reply With Quote
Old 03-29-2009, 04:33 AM   #3
pear69
pear69 Normal reputation
Your problem started with a temperature change. Go from there. A coolant sensor or air intake temperature sensor will cause your problem. Also, a failed crank position sensor will cause your problem too.
pear69 is offline   Reply With Quote
Old 03-29-2009, 10:17 AM   #4
j cAT
j cAT Normal reputation
you should check the ECT sensor...if the sensor is out of range the computer/pcm will not properly deliver the correct fuel for cold start....
since the plugs where flooded with fuel they must be replaced...
the ECT produces a resistance that must match the spec.
at 40deg f it should read 3-4,ooo ohms....you can measure with out removal...
j cAT is offline   Reply With Quote
Old 03-29-2009, 10:29 AM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Proper testing before throwing parts at it.
To check for fuel delivery problem see if it will crank with a shot of carb cleaner.
On the code clear code and see if it comes back.
If it does go threw the repair flow chart for that code.
Bad or lose wiring or wiring plugs can ause that code.
Confirm good hot blue spark to all plugs.
Pull plugs and check for wet or dry on end.
If dry you are not getting fuel.
Give it a shot of carb cleaner.
If wet check for good hot spark and replace plugs.
Fuel pressure at 60 lbs is low.
You need 65 for a cold start for injectors to squirt.
The only true test on a fuel pump is to check the direct fuel pressure from fuel pump.
A quick test is to block off the return line and see if fuel pressure comes up to 75-85 lbs.
But do not run the pump at full pressure very long.
Also when testing fuel pump and pressure you need to tape a gauge to outside windshield or outside mirror and drive it on the road for 20 -30 minutes
until the pump gets has run a while to check for a pump fading out after hot.
Hard to start cold or hot and fuel pressure testing guide lines.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
If pump has full pressure with return line blocked and low pressure without it blocked most usually the fuel pressure regulator is leaking or not holding pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak in system.
Post back fuel pressure readings.
MT
MT-2500 is online now   Reply With Quote
Old 05-08-2009, 11:32 PM   #6
1996pmt
1996pmt Normal reputation
navyguy did you get the problem figured out? i have a 1996 z71 with a 1998 5.7l in it and im getting the exact same problems. same codes and syptoms. please let me know
1996pmt is offline   Reply With Quote
Bookmarks
Google
Web AF
