Re: door roller popping - not hinge pin
yep.. have been oiling it up. I even took the spring off the door with my special spring tool. After I took the tension off it, it spun freely with no noise. but with pressure on it from the spring it pops as the door is opening / closing. I fear that if this goes unchecked it will wear the roller soo much that the door won't be able to open or close properly..(not that it does now). Worst case scenario I'll have to take the spring out and just use it that way. Or is there a surefire way to replace the roller?
