2000 blazer 4wd, 4.3l low oil pressure? HELP!
Google
Web AF
blazina
03-27-2009, 05:02 PM
My wifes 2000 blazer 4.3l v6, 4wd has 170,00 + miles on it. My question is regarding the oil pressure. What shouild the oil pressure be at highway speeds of 60-70 mph. The pressure goes up to just over 40 at those speeds but when she stops or puts on the brakes it goes down to 20-25. Is it time for a new oil pump or is the motor on it's last leg?
ALSO I CHANGED THE OIL A FEW DAYS AGO, THERE ARE NO LEAKS AND THE OIL LEVEL IS NOT LOW.
MT-2500
03-27-2009, 06:37 PM
It is well within factory specs.
Before you go throwing parts at it check the actual pressure with a oil pressure test gauge.
Post back readings.
If the test gauge reading does not match the dash gauge replace oil sending unit.
And retest.
MT-2500
03-27-2009, 06:43 PM
Minimum oil pressure specs for 2000 4.3 V6 with engine hot.
1k RPM 6 lbs.
2K RPM 18 lbs.
4K rpm 25 lbs.
b1lk1
03-27-2009, 08:33 PM
Agreed, my oil pressure drops at idle when it is hot but is well within spec so I ignore it.
djd99
03-28-2009, 11:31 AM
Just about all gm engines run between 20 to 40 psi, 20 when at low rpm is normal.
Google
Web AF
