Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > El Camino
Old 03-26-2009, 09:33 PM   #1
Suchalif77
Suchalif77 Normal reputation
87 El camino no spark problem
I have an 87 El Camino with a stock 305 that I just bought.I have bought a new battery,fuel pump,distributor,computer,and carefully rebuilt the rochester carb.It will crank but won't start.I have set the points from #1 on the dist.There is no spark from the dist. to the plugs.What am I missing?Everything seems to be in order,but still no spark.The coil is fine.
Suchalif77 is offline   Reply With Quote
Old 03-27-2009, 01:11 AM   #2
cherryelky305
cherryelky305 Normal reputation
Send a message via AIM to cherryelky305
Re: 87 El camino no spark problem
have you checked voltages that feed the distributor? maybe theres a bad wire some where, also look around really good for all your grounds.
This site might be of some use for your. its wiring for G/bodies, I think it will work for you.
http://www.maliburacing.com/wiring.html
Should be under V8 ignition system. Good luck.
1980 El camino
2002 LS1 swap
cherryelky305 is offline   Reply With Quote
Old 03-27-2009, 09:15 PM   #3
rhandwor
rhandwor Normal reputation
A bad condenser will cause a no spark condition. I put in a new set of points that had set around a long time I had to use contact cleaner and clean them.
rhandwor is online now   Reply With Quote
Old 03-29-2009, 05:39 PM   #4
Suchalif77
There is power going to the distributor.I've checked grounds.Still no spark.There is no condenser on my distributor.I have the newer hei distributor.Could it be a electronic spark control module?
Old 03-29-2009, 06:32 PM   #5
rhandwor
You should have 12volt power coming from the ignition switch if I remember correctly. When you said you set your points I was thinking an older car.
The power should be a large red wire. Maybe purple on ignition switch.
Advance and Auto Zone will check the modules free.
Old 03-29-2009, 07:08 PM   #6
ctwright
ctwright Normal reputation
If your distributor has points you don't need an icm b/c that is how your coil get's it's ground pulses. You should have 12 volts to the positive side of the coil with the ignition in the on postition. The points are breaker points in the ground which pulse the ground to the negative side of the ignition coil.
Other vehicles that don't use points use crank sensors and an ignition module to get ground pulses to the coil.
ctwright is offline   Reply With Quote
Old 04-06-2009, 06:28 PM   #7
Suchalif77
I finally tracked it down.I had two ignition coils.When I did regular resistance tests they both checked out fine.There still was no spark so I went ahead and bought a new one.There was spark!Thank you to everyone that replied!
Bookmarks
Google
Web AF
