2000 grand prix diclittlebachy 03-24-2009, 05:37 PM driver information center is flashing 0 in all modes. sometimes when I initially turn key on everything works for about 10-15 seconds. the traction control off light is luminated all the time. On the second day I noticed that the little guy on the heater control screen is flashing for a couple minutes then stays on. What should I look @ first? Thanks FullyAvenged 03-24-2009, 07:23 PM Disconnect the battery for 10 mins and then reconnect. See if it helps. richtazz 03-25-2009, 09:33 AM Welcome to AF. Your issue sounds like an ignition switch/harness issue to me. It's a very common problem on these cars as they get older. The contacts start to arc, and cause all sorts of odd electrical gremlins including DIC anomalies, HVAC problems, dash/IP lights, etc... littlebachy 03-26-2009, 09:47 PM I tried disconnecting the battery for 10 min. Still the same. littlebachy 09-02-2009, 10:50 PM It's been awhile. I still have the problem and a few more. The shifter indicator flashes in and out on dash and the outside temp. is reading in the 100's when it's 70 out. I replaced the DIC back in may. The screen went out and i thought that was the problem but back to the 0 reading now. Could it be a corrosion/connection problem in the ignition switch/harness or do I need to replace? richtazz 09-03-2009, 07:57 AM I would say with your combination of problems, the ignition switch/harness is the most likely cause. littlebachy 09-03-2009, 09:57 AM Thank you. I am going to replace the harness today. littlebachy 09-03-2009, 09:58 PM replaced ignition switch/harness and still have the same problems. I did replace the DIC unit and still the same. What could I look at next? BNaylor 09-06-2009, 01:45 AM When the DIC flashes 0 in all modes it indicates loss of serial data with other components such as the PCM or BCM modules so the best thing to do is get it scanned with a scan tool like a GM Tech 2 capable of retrieving and reading out GM body/chassis codes. Otherwise you could be looking for a needle in a haystack or just wasting more money on parts not resolving your issue. littlebachy 01-19-2010, 10:49 PM Hey I finally solved the problem. The main wire harness running on driverside goes around the condensor and then goes to ECM. Well a mechanic at dealer informed me that they had issues with the harness rubbing on condensor. I had 5 wires rubbed through. repaired and all the problems went away. She's a new car. Thank You for your time and suggestions.:grinno: vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
