Thanks 98SableGS & ctwright for your replies. I'll definitely check into all that.
As for the "AC system charging kit", would that be the same as a "Freon Charging Kit" like
these at Autozone?
Also, I've researched the voltage regulator, and discovered that I must replace the entire Powertrain Control Module (PCM) to replace the voltage regulator. I've found some instructions for doing this
here, but now I must find a place to obtain a new PCM as well as a "scan tool" to program the new PCM with the VIN & mileage. Any suggestions there?
