Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Monte Carlo
Old 03-23-2009, 07:52 PM   #1
emba129
emba129 Normal reputation
98 Monte carlo Z34 Alternator 3.8L
Can someone tell me how difficult an alternator is to change on a 3.8L Z34. It looks straight forward as it in on the top of the engine.
What is the stock amperage and what do you recommend as a good replacement? Same amperage? or more?
thanks
Chris
emba129 is offline   Reply With Quote
Old 03-24-2009, 05:01 PM   #2
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: 98 Monte carlo Z34 Alternator 3.8L
the alternator on your car is about as easy as it gets. Disconnect the battery, remove the serpentine belt, disconnect the voltage regulator harness plug on the alternator, the main battery feed cable on the back of the alternator (10mm or 13mm nut), and the two alternator mounting bolts and it's in your hand. Your car most likely had 105 amp alternator from the factory. There was a 140 amp optional unit, but it isn't interchangeable with the 105 amp (it has a different voltage regulator plug and a wider mounting bolt pattern). There are rebuilding shops that may be able to put higher output windings into your original unit if you have a big stereo or other electrical add-ons, but the 105 should be more than enough.
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Bookmarks
Google
Web AF
