Re: 1994 safari brake pulling problem
Quickest, easiest way to see if it's rears causing the drift is to line lock the rear brakes at the rear flex hose and drive it, CAREFULLY. A small "C" clamp works well, tighten it just enough to stop fluid flow. If the drift is gone, check the rear brakes and repair/adjust if/as necessary. Keep in mind during the road test, you are only using the front brakes. The proportioning valve safety shut off will not operate if there is a hydraulic failure in the front system leaving you with NO brakes.
