Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 03-22-2009, 07:47 PM   #1
disembodiedsoul
disembodiedsoul Normal reputation
1994 S10 Blazer confusion
My '94 S10 Blazer has a problem, it starts, runs but when is revved or put in gear and try to move it the engine first lopes badly then stalls. I have Checked Fuel pressure and is range.. new cpi spider, distributor good, ignition module good, ecm operating as it should, tps working, no vaccum leaks, and the intake and plenum have new gaskets. Map sensor working properlyand timing is right. What could possibly be my problem? beforei for get it is 4.3 cpi vin # w with 140k miles
disembodiedsoul is offline   Reply With Quote
Old 03-22-2009, 08:48 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Re: 1994 S10 Blazer confusion
Start with the basics: What is the fuel pressure and leakdown rate?
old_master is offline   Reply With Quote
Old 03-22-2009, 08:55 PM   #3
disembodiedsoul
when runing it holds 60-63 and when not runnin 56-58
Old 03-22-2009, 09:04 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
94 4.3L "W" engine fuel pressure spec is 55psi to 61psi with the key on, engine cold and off. There is no published "engine running" fuel pressure specs, (far too many variables involved). Your pressure is fine, what is the leakdown rate? Fuel pressure must remain above 50psi for 3 to 5 minutes.
Old 03-22-2009, 09:09 PM   #5
disembodiedsoul
fuel pressure indefinatly stays above 55psi
Old 03-22-2009, 09:09 PM   #6
old_master
Advisor/Moderator
old_master's Avatar
Have you checked/adjusted ignition timing?
Old 03-22-2009, 09:11 PM   #7
disembodiedsoul
yes base timing is good
Old 03-22-2009, 09:14 PM   #8
old_master
Advisor/Moderator
old_master's Avatar
O degrees with the EST wire disconnected, (tan wire with black stripe taped to wire harness near the distributor)?
Old 03-22-2009, 09:17 PM   #9
disembodiedsoul
yes and before i would forget it had set off codes 22 and 34 tps voltage low and map voltage low, a possible short? and a code 83?
Old 03-22-2009, 09:19 PM   #10
old_master
Advisor/Moderator
old_master's Avatar
What order did the DTC's appear when you retrieved them?
Old 03-22-2009, 09:47 PM   #11
disembodiedsoul
83 then 22 and then 34
Where is my body??!!
Old 03-22-2009, 10:18 PM   #12
old_master
Advisor/Moderator
old_master's Avatar
83 is for reverse inhibit system on vehicles equipped with manual transmission only. That DTC will not turn on the SES.
22 indicates the TPS showed less than .2 volts and 34 indicates no MAP signal was received at the ECM.
If either sensor was disconnected with the ignition in the RUN position, it will set these codes. If that's not the case, look for an open, not shorted, circuit for the TPS and the MAP sensors.
Old 03-22-2009, 10:26 PM   #13
disembodiedsoul
ok thank you for you help and i was out and did find some one had hacked into the wirin harness. and would that be the purple wires i saw corroded?
Old 03-23-2009, 05:09 PM   #14
old_master
Advisor/Moderator
old_master's Avatar
The MAP sensor has 3 wires: Light green, Purple, & grey.
The TPS also has 3 wires: Dark blue, Black, & grey.
Repair them by soldering, not crimp connectors, and use heat shrink tube to insulate/weatherproof them. Post your results.
Old 03-23-2009, 07:19 PM   #15
disembodiedsoul
results are the same is it possonle some one replaced the engine with a '93 if so si that engine comatible with a 94 wire harness??
Bookmarks
Google
Web AF
