2001 Silverado Out of time?
Hello,
Please bare with me as this is my first post.
I have a 2001 Chevy Silverado, 1500, 4x4, automatic, 5.3 V8.
While pulling into the parking lot at work, my truck just died. It was as if someone turned the key to run. I still had battery as the instruments and lights were all working. I managed to push it into the parking lot and test a few things. I was able to start the truck Only if i put the pedal to the floor and cranked for a while. After I got it started, it ran as if i was only firing on 3 or 4 cylinders. I ended up towing it home and was able to check all the basics. Here is what i have done so far:
With an OBD II scanner i was able to read codes and it gave me a P0300 Random Cylinder Misfire.
I changed out plugs and wires about a year ago. I checked to make sure i had spark at each plug. I pulled spark plugs one at a time and found that about 5 of them were wet with fuel however each plug was getting spark. I was able to check the coils by swapping coils with my dads truck (same truck only two years newer). Doing this made no difference.
I swapped MAF sensor...no difference. I swapped MAP sensor...no difference. I tested and bypassed the EGR Valve and this made no difference.
I tested fuel. Fuel was about 57 PSI sitting with key in the on position. I let it sit with the gauge on there for an hour and the pressure still held. I then checked it with engine running (barely). Fuel pressure was about the same.
I replaced the camshaft sensor and crankshaft sensor which made no difference.
I also checked compression in all cylinders and found that all cylinders except one had about 170 lbs comp. Cylinder # 6 had zero lbs. I tested this cylinder with compressed air and heard air in both the exhaust and the intake.
Because the truck is running like it is out of time, do you think the timing chain slipped a couple of teeth or could I have a broken or burned valve in cylinder 6. And if it is a broken valve, would it mess up all the rest of the cylinders and make my truck sound like the timing is way out of wack? Sorry for being long-winded. I just want to try to cover everything i have done so far. Any help would be greatly appreciated.
Thank you
