Re: Camry Steering Problem
If there is too much cross caster, (difference in caster from driver to passenger side), it will cause a pull or drift. Caster will not wear tires if it's out of spec, but can be annoying to drive, as you already know. It may not be adjustable on the Camry, (it's not adjustable on most front wheel drive vehicles). After they align the front end, ask the technician what the cross caster is on your vehicle. Maximum cross caster should be no more than .5 degrees. If cross caster is excessive, and not adjustable, it can get very expensive to correct it.
