99 durango vibration and noise
I own a 1999 dodge durango 4wd and have been experiencing the following problem:
A vibration and noise that i can best describe as what sounds like tire noise. The vibration can be felt in the steering wheel to a certain extent and the noise can be heard at all driving speeds, though it does slow down and go away when you stop.
My initial thought was bad tires, but the noise is there when off road and on snow, the tires have also been replaced to no effect. The noise is worst at around 40 miles per hour and goes completely away when cornering to the left.
Here is what has already been done to try to eliminate the problem:
New tires and tire rotation.
New front brake rotors, calipers and pads.
New rear brake drums and shoes.
New front 4 wheel drive hubs (around 15k miles ago)
New ball joints (upper and lower) and tie rod ends (with alignment).
Exhaust inspection and repair (where necessary)
Drive shaft and universal inspection (should the front drive shaft always turn?)
New rear end seals and balanced the rear drive shaft.
Any input would be helpful.
thanks
don
