Lower Motor / Transmission Mounts
tblake
03-19-2009, 01:24 PM
Hey Guys, can anyone give me any info on the solid rubber motor and transmission mounts from ZZP?
I think my trans mount on the passenger side is shot, and my motor mount on the drivers side got covered with grease from a bad axel shaft. So they probably should both get replaced.
You all know my track record with aftermarket parts. Anyone use the sold rubber ones from zzp?
How hard is it to replace these? Subframe has to be removed?
Thanks!
BNaylor
03-19-2009, 02:50 PM
PITA of a job Tim. How did you verify they need replacing? Do you see pieces of the rubber insulator coming off or the insulator split down the middle? Any weird vibrations being felt inside the cabin like at the dashboard or steering wheel. Vibrating outside mirrors?
To replace the mounts you need the engine/tranny hoist and yes the subframe is dropped or removed, if you prefer.
tblake
03-20-2009, 12:40 AM
ahhh man. thats what I thought.
The lower motor mount looks like its in decent condition, the trans mount seems shot. The whole motor rocks a lot when I go from park to reverse and reverse to drive.
BNaylor
03-20-2009, 03:43 PM
That doesn't sound good. What about the two wishbone engine mounts.
tblake
03-21-2009, 12:17 AM
I'm off tomorrow Bob, I will have a closer look then and report back. Thanks!
tblake
03-21-2009, 01:19 PM
Bob, guys, the motor mount is the mount on the drivers side or passenger side?
