00' 5.3 1500 Water Pump Replacement Question
mytime
03-17-2009, 10:19 AM
Just found this forum and have been reading the posts. Great info. I need to replace the water pump on my 00' 5.3L 1500 Z71. I would appreciate and links or info showing what needs to be removed in order to get the clearance to do this and anything I should look out for.
One other issue I have been having lately is that the tranny seems to be shifting out of OD on moderate hills at lower RPM's. Is this common on this truck and can I adjust the shift points to keep this from happening. Other than that 117,000 miles and running great.
Thanks in advance for the help.
rjeffery
03-17-2009, 01:48 PM
A Haynes manual will give you step by step directions with illustrations for replacing water pump. I followed it to replace my WP on my 02 4.8 and it was very straight forward.
j cAT
03-20-2009, 10:25 AM
if you drive in an area of hills and the speed is 40-50mph,,,,do not use OD...this will save your transmission from excessive shifting....shifting wears the transmission and adds heat to the fluid/wear...
this is in the owners manual!
2000CAYukon
03-20-2009, 01:13 PM
Using the Tow/Haul Mode does change the shift points. I find that using Tow/Haul along with the Tranny in D works well on moderate hills in my area.
//2000CAYukon
mytime
03-24-2009, 03:57 PM
Thanks for the info. Replaced both the water pump and the power steering pump while I had everything out and the truck runs great now. Not issues at all.
