High fuel pressure
southpole9347
03-17-2009, 12:18 AM
did intake gaskets.. put it back together runs like crap has 60 psi koeo for more than 5 mins.. start it up it has 80-100psi.. replaced fuel press reg. unhooked return line where it turns to metal right next to fuel filter pours out like a siv.. replaced distrubtor checked timing a million times checkes firing order no vacum leaks that i can see or hear.. anyone got any hints? anyone with this problem before? and also how do u no if ur gettin enough vaccum in the upper intake to pull open the fuel press reg? or whatever it does im not to sure about this 43 spider injection shit.. all i no is they should have just went with a coil on plug or somethin with a regular injector but anyway i need an expert on the fuel system on these 4.3's thanks
Airjer_
03-17-2009, 01:54 AM
Maybe its restricted further back by the tank, pump, or in the pump?
MT-2500
03-17-2009, 09:44 AM
Open your ears.
We have been trying.:lol2:
http://www.automotiveforums.com/vbulletin/showthread.php?t=945369
old_master
03-17-2009, 08:06 PM
Direct the return line into a bucket, (where you took it apart by the fuel filter is fine). Turn the ignition to the RUN position, but do not start the engine. The fuel pump will run for approximately 2 to 3 seconds and then shut off. Check fuel pressure while the fuel pump is running. If the pressure is 60psi to 66psi, the restriction is rearward of where you took it apart. If the pressure is above 66psi, the problem is forward from where you took it apart.
southpole9347
03-18-2009, 12:46 AM
see what i dont get it is with the truck running and a fuel gauge hooked up to it if u hit the bleed off button on the gauge it drops right to 60 and runs fine but if i unhook the return line from the quick connect next to the fuel filter it runs rough still ill try unhookin it farther back but it doesnt really make sense to me if it was a clogged return and i take it off and it comes out fine with high pressure and runs the same how is it going to be farther back if there was a restriction back by the tank when i unhook the line it should run fine.. thanks though
old_master
03-18-2009, 04:45 PM
There are NO published "engine running" fuel pressure specs. There are far too many variables involved to specify a certain pressure that would apply to all situations. ALL fuel pressure tests are done with the engine off and cold. Keeping that in mind, go back and run the test described in post #4 and post your results. Make sure the fuel pump is running when you check the fuel pressure.
