Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Tercel
Old 03-16-2009, 02:19 PM   #1
kauferlie
kauferlie Normal reputation
PCV Valve 96 Tercel Stuck
Seems to be really stuck in the engine.
Do I just pull hard without fear?
kauferlie is offline   Reply With Quote
Old 03-17-2009, 09:55 AM   #2
gator2764
gator2764 Normal reputation
Re: PCV Valve 96 Tercel Stuck
Do you mean it is stuck in the valve cover? If so the rubber grommet is most likely just hard and brittle. Pull it out.
I would go ahead and have the tranny flushed, no sense leaving the old stuff in there.
gator2764 is offline   Reply With Quote
Old 03-19-2009, 08:51 PM   #3
rhandwor
rhandwor Normal reputation
Why would you recommend a transmission flush for a bad Pcv valve in the engine.
You might use a screwdriver and pry lightly. Get a new rubber grommet at the parts store or dealer.
rhandwor is offline   Reply With Quote
Old 03-20-2009, 06:12 AM   #4
gator2764
Because the poster had 2 questions about this car, he just didn't ask them in the same post.Figured I would just answer them both in one post.
Old 03-27-2009, 11:00 AM   #5
kauferlie
So, flush, and not replace fluid?
I thought I had heard that flushed can mess up trannies?
Old 03-27-2009, 12:43 PM   #6
gator2764
If you are afraid to do a power flush on it just pull the car up on ramps, drain the pan, refill it, drive it around the block and repeat about 6 times. I have done this numerous times, it just takes a bit longer than having an oil and lube place flush it for you.
Old 03-27-2009, 12:52 PM   #7
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
Drain & fill 2 times is sufficient for tranny fluid. Don't neglect the differential fluid as well...it has it's own separate reservoir.
As for the PCV, let the engine cool then use a screwdriver or small pry bar to ease it out. As mentioned, the grommet holding it is likely old and embrittled. If you do replace the grommet, take care to not let any pieces of the old grommet fall into the valvevtrain. Best and safest way is to remove the valve cover first and work it out while off the car. Good luck!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Old 03-27-2009, 08:36 PM   #8
kauferlie
Thanks for the advice and directions.
Bookmarks
Google
Web AF
