Engine Swap or Tranny Swap????????tempfixit 03-15-2009, 02:26 PM I am considering either doing a engine swap or tranny swap. The vehicles are a 93 Voyager 3.3 with bad tranny good engine and 94 Voyager with bad 3.3engine and good tranny. Both body's in good shape. Here is the thread about bad engine: http://forum.chryslerminivan.net/showthread.php?t=11232 If doing a engine swap what are the best lift points on the engine???? Thanks for any thoughts and tips ctwright 03-15-2009, 02:44 PM I would swap out the transmission not only because the the one with the bad one is newer but also it should be easier. littlebitofinsanit 03-15-2009, 03:21 PM check same engine no differances bolt pattern see if same tranny there is 3 spd or four if one has 3 spd i would keep that more realiable then four tempfixit 03-15-2009, 05:05 PM Sorry I should have been a little more clearer. The 93 has a 3.3 good engine with bad transmission (4 Speed) and the 94 has a 3.3 Bad Engine and good transmission (4 speed). To my knowledge everything should be compatable. Does anyone know when Chrysler stopped installing the Bendix brake system???? ctwright 03-15-2009, 07:53 PM My bad I got that mixed up, the newer one has the bad motor. Automotive Network, Inc., Copyright ©2012
